주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 질문 전체 보기
Left channel on headphones not working
My iPod recently started only playing audio out of the right channel of my headphones, for no apparent reason. Previously it had been known to not play audio at all, though I think that may have been due to cold when trying to use it, as the problem subsided.
I purchased a new jack and hold button part here in the UK, as well as new screen (since that had lighting issues) and front panel and radial button, and have performed the replacement following the instructions on this site without any issues.
However, the left channel still fails via the headphone jack.
When playing back via a docking station, there is audio from both channels, which would lead me to suspect that the logic board is fine (though ISTBC).
I have tested this both with Apple headphones and my own set which I know to work on both channels, and neither produce positive results.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
I would then guess that the logic board of your iPod is unfortunately damaged in some way. I do not believe that the logic board has problems with processing audio, I believe it has a problem with outputting it to the headphone jack. The audio may come through the dock connector perfectly because it is a completely different port controlled by completely different parts. But, the board may have something going on when it tries to output audio to the headphones.
Have you checked the connection of the headphone jack to the logic board? A partial disconnection can cause issues. If you go back in, you might consider taking a look around the headphone jack connector on the logic board. See if you notice any water damaged/charred parts.
Hope that helps a little. Sorry it's not a solution. :/ You've done a great job of ruling out the prime suspects though. If it wasn't the headphone jack, it could have either been the headphones or the logic board.
In this case, I suspect the logic board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yeah, it's looking that way. Thanks for your reply. I'm probably going to take it apart again, make absolutely sure that I've connected everything correctly, and that there are no bad contacts, and if still failing, think about swapping out the logic board. Sadly that does take things a bit over the budget that I had set out for the repair project, but I'll sleep on it and see. Thanks again. :)
댓글 달기
귀하의 답변을 추가하세요
Kassidy Kearey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 4,344
