주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
iPhone 4 time is December 31 1969
I got an iPhone 4 off ebay in a parts lot. After disconnecting and reconnecting the battery for no reason, the phone time shows December 31 1969. One of the Liquid indicators in the motherbord is RED. Could the incorrect date be a sign of water damage, even though I think the date was correct before unplugging and reconnecting the battery?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
When the battery is unplugged the date and time is reset because there is no battery on the logic board to keep the date and time in memory.
The date and time will retain if the battery is not too flat or unplugged, when the phone is connected to internet it will re-synchronize the date and time to current time if date and time is set to do it automatically in settings.
The LD indicate can be a indication of possible liquid damage note that these stickers turn red even from just humidity.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
OK, I will connect the phone to internet and clean the board with Alcohol to get rid of possible liquid damage
댓글 달기
귀하의 답변을 추가하세요
Dinan Blueje 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 135
