Are this model's logic boards interchangeable
Now I know, it was not an opportunity to purchase a MacBook Pro 17", i5/2,53 GHz, Mid 2010 in 2016. I got it at a good price without knowing the problems of this particular model. Now I have problems that can't be fixed and I have to change the motherboard. I found that the same MacBookPro6, 1 model comes out with more than two models of motherboards and one of them has an Intel i7 processor.
- Can I use this motherboard (i7) for my own MacBook Pro 17"?
- Uses the same openings for the input ports?
- Does it have the same holes for the screws that support it into the enclosure?
- Can I use the same as before internal HD and SSD?
- Can it work with the same fans model?
- With the same battery model?
Please Advise!
좋은 질문 입니까?
댓글 2개
Maybe we can fix the problems that you can't, there a lot of wisdom and experience here. How about telling us about it first?
mayer 의
@mayer My dear friend, thank you for your concern.
The machine, due to overheating (95-96 centigrade), probably damaged the left built-in loudspeaker and all audio inputs except the built-in microphone. It does not recognize a microphone on either the USB port or the 3.5 mm coaxial mixed headset/microphone port. I have audio output on both headphones, USB and built-in loudspeakers(distorted). Microphone, just the built-in.
I plan to buy a new logic board and using TG-Pro, I recently discover, keep the temperature bellow 85 degrees. I guess this maximum temp will be fine.
That's all
Manos 의
