주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Looking for a short on VCC MAIN, injected 4.2v blew component
Title pretty much sums it up. I soldered a wire to a cap near the pmic. I hooked the positive up and heard pop and saw a little puff of smoke.
I had a diode reading on vcc main of 0.152, thats why i tried to inject voltage, but as soon as i did the voltage limiting on my dcps kicked in and voltage went to 0 while amps went to 5.16.
The strange thing is that i went through each component and cap on main but didnt find the fried component. Any ideas on what happened, this is the first time ive injected voltage into a line so im unclear on safe voltages to find a short but not blow it off the board.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
pts8091 post a good picture of where you soldered to the Cap. with your question. That way we could try and trace the circuit and see if we can find the smoked component. 기존 질문에 이미지 추가하기
댓글 달기
답변 1개
I am all for injecting power during troubleshooting but you also need to have a fused power protection that will blow before the item you are working on blows. I am not a phone technician so I would recommend a small fuse, say .5A, to start out and increase the size as you gain more experience or see that a 2A fuse still allows components to go up in smoke. If you have an adjustable power supply with current limiting that start that out at a low current potential and increase as needed for safety.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
pts8091 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 53
