주요 콘텐츠로 건너뛰기
The Dremel 4000 is a variable speed rotary device. It is compatible with with all Dremel rotary accessories.
Dramel 4300 rotary tool 120v
I placed my tool into a 220v socket yet it takes in 120v and it stop working any help on how to replace the Electrical Assembly Replacement unit for the dramel 4300 Rotary tool and where i can find an Electrical Assembly Replacement for the Dramel Rotary Tool
i have used the picture for the Dramel 4000 becouse the admin seems not to have Dramel 4300 in the drop down
thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
You probably burned out the motor when you plugged it into a 240V outlet How did you manage to do that? normally the plugs are not compatible.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Could be in a foreign country that uses universal outlets? I am an American Vet living in the Philippines and I changed some of my outlets to accepts everything, I also have a commercial grade transformer for 100 and 120 while local voltage is 220. locally they do not have a third ground connector and also do not have the wide spade (polorized) connector as the USA does. Not sure how simple the dremel plug may be? I also believe that there could be 220 in the USA but the OP is saying 240 so I believe this is not in the USA.......
I recommend to open the tool, see if there is a possible fuse, if not, then replace the entire unit, by the time you get a replacement part, if available, and your time to change it, you will not save much money in the end.
댓글 달기
답변을 추가하세요
Brighton Albert 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 1,050
