주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The keyboard for Microsoft’s 2-in-1 laptop released in October of 2015. 6th Generation Intel Core i5 or i7
Where can I get the glue to reassembly the Keyboard?
Hey Guys, where can i get the glue to reassembly the keyboard? Which kind of glue has to be used? Can i use regular hot glue? Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
I would not use hot glue as it will release when the base gets hot during use. A very light coat of contact cement will do the trick.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
https://www.tesa.com/en/industry/tesa-61...
Tesa 61395 Tape
I used 2mm to put mine back together. Might be worthwhile getting a mix of 1mm, 2mm, 3mm, and 4mm if you want to be thorough. Otherwise, just 2mm does the job.
Custom cut rolls of Tesa 61395 double-sided tape for repair. 이미지
제품
Tesa 61395 Tape
$8.95
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I used only 2mm tape on mine and after 6 months it is coming loose in the places where the original tape was wider. It's too bad that someone doesn't sell the tape in a template like it used at the factory.
댓글 달기
답변을 추가하세요
Finn 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 43
전체 시간: 1,147
