주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
구글의 3세대 픽셀 브랜드 스마트폰이자 최초의 '홈 화면' 스마트폰입니다. 6.3인치 QHD+ OLED 디스플레이와 64GB 또는 128GB 저장 용량을 제공합니다. 거의 흰색, 저스트 블랙 또는 핑크색으로 제공됩니다.
My phone doesn't work
So I sat on my google pixel 3 xl. When I did so I heard a crack sound like a screen broke. I got up and looked at my phone and it will not turn on, vibrate, or make any sounds to let me know if it still works. Before I sat on it had a cracked screen in the very bottom corner, not even where the OLED screen is, it’s right next to the speaker. Everything still worked just fine before this. Google wants me to fix the screen then they will try to fix the problem. I just want to know if you guys think you know what could have caused the problem, so I can fix it myself or something.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi Cooliphonexbox,
the damage is depending on the force of the pressure. You must disassemble your mobile phone and check what’s damaged and what could be the best solution to fix. It may be damaged motherboard of phone or just issue with the connection between the screen and the PCBA. If you don’t have experiences with measuring PCBA or functional test, give the mobile phone to the repair center, in the other way, follow quick guide
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Cooliphonexbox 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 7
전체 시간: 184
