주요 콘텐츠로 건너뛰기
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
85 질문 전체 보기
Battery keeps going bad in same device
Here’s the scenario: My customer is a pilot who flies small, private planes. He uses the iPad Air 2 to file flight plans and as a navigational aid. The device is always with him when he flies. It has had some bumps and bruises, the frame was bent at one point, but we were able to straighten it out. Overall, it functions just fine.
May 2018: I replaced a very swollen battery in the device. (The glass was separating from the frame.)
January 2019: The May battery was swollen and again, the glass was separating from the frame. I replaced that battery, straightened the frame, and sent him on his way.
October 2019: Battery is swollen again.
Any ideas as to what could be causing this device to go through batteries so frequently?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Does he leave it plugged in the entire time he’s using it? If so I would imagine it would be from that. Also, depending on the altitudes he’s flying at, the lack of air pressure could cause the battery to swell as well.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jeana Morales 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 25
