주요 콘텐츠로 건너뛰기
2018년 10월 26일 출시. Models A1984, A2105, A2106, A2108. GSM 또는 CDMA / eSIM, nano-SIM 또는 dual-SIM / 64, 128, 또는 256GB / 검정색, 흰색, 파란색, 노란색, 산호색, 또는 빨간색. ("iPhone 10 R"로 발음합니다.)
468 질문 전체 보기
iPhone XR sensitive dongle causing random playback issues
I’ve tried listening to several different apps and always have the same problem and I’ve also tried different earbuds (with cords).  The dongle seems sensitive and every time it is touched a certain way, it causes apps to have a mind of its own and even skips whole episodes of podcasts, pauses, and plays.  I can’t workout with music because if I just walk, it stops the music and it is infuriating.  How can I fix this without having to buy Bluetooth earbuds?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If you are referring to the lightning to 3.5mm headphone jack adapter then the socket on the adapter is worn out which means you'll need to buy another lightning to 3.5mm adapter.
Try cleaning the socket with something like 95% isopropyl alcohol and a cotton swab (remove some of the cotton to get it to fit in).
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
yup. i'm pretty much gonna have to replace it. That's what i get for not having a protective case for so long.
댓글 달기
귀하의 답변을 추가하세요
Andrew 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 2,830
