주요 콘텐츠로 건너뛰기
Released April 2018. Identified by model number EML-L29.
22 질문 전체 보기
[P20 Lite] Is the problem with my screen or motherboard?
I was given a phone what had fell down from a high place, if you turn the phone on / or put the charging cable in the phone, the phone vibrates, a flashing red-light occurs at the top of the phone and screen gets some red&blue&green lines running through it.
I’d like to know if the problem is with the screen or the motherboard, is it worth fixing?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi @roal ,
it’s a LCD&Digitizer issue. Follow this video to see, how to repair your issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks, just put my order in for new LCD & frame.
Cheers mate, hopefully I'll be able to make the repair :)
You are welcome, you will fix it! :) Good luck
댓글 달기
귀하의 답변을 추가하세요
Raul 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 21
전체 시간: 1,299
