주요 콘텐츠로 건너뛰기
Repair guides and support for motorcycles manufactured by Honda.
speedometer and tach lights not working.
i have a 96 honda gl1500 se. the dash lights work but the speedometer and tach lights do not. any thoughts?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 3개
가장 유용한 답변
  • Speedometers are unique in that some of them use physical cables instead of sensors, so a speedometer not working can also indicate a broken cable or stripped gear.
  • If one or more warning lights fail to illuminate when you first turn the key on, it usually indicates a blown bulb.
  • If none of the lights come on at all, check the fuses and wiring to the instrument cluster first.
  • If a warning light comes on and stays on when the engine is running, that usually indicates a problem with that specific system.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
I am sorry I wasn't clear on the request. What I meant was everything is working properly except the lights on the speedometer and tach. Makes it very difficult to drive at night.
댓글 달기
Speedometer light Horan not working
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have a splandarbike but many problam this bike Bhai is smoking and the noise is very directly and not speed
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ken_choat 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 31
전체 시간: 3,615
