주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
iPhone X restarts every 5 minutes after backreplacement
Hello,
I switched the backglass and the frame but since then my iPhone keeps restarting every 5 minutes. The new backframe arrived with parts like charging port, taptic engine. I’ve kept them inside. The crash report of analytics is:
{"bug_type":"288","timestamp":"2019-10-13 18:42:47.85 +0200","os_version":"iPhone OS 13.1.2 (17A861)","incident_id":"8C446476-CA19-47A0-8F74-5803B0A9A4A8"} { "build" : "iPhone OS 13.1.2 (17A861)", "product" : "iPhone10,6", "kernel" : "Darwin Kernel Version 19.0.0: Tue Sep 3 21:52:10 PDT 2019; root:xnu-6153.2.3~2\/RELEASE_ARM64_T8015", "tuning" : { }, "incident" : "8C446476-CA19-47A0-8F74-5803B0A9A4A8", "crashReporterKey" : "413cb2f10b0936293a261e8ec514288966bd25a5", "date" : "2019-10-13 18:42:47.85 +0200", "reason" : "(1 monitored services unresponsive): checkin with service: com.apple.thermalmonitord returned not alive with context:\nis_alive_func returned unhealthy : current 1ffc73fffffffff, mask 67fffffffff, expected 67fffffffff\nno successful checkins since load (130 seconds ago)", "frontmostPids" : [ 58
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
I definitely have the same problem, I reset the settings, I did a hard reset, but the problem continues
problem is iphone se
edit: model
댓글 달기
답변 7개
가장 유용한 답변
Ive seen this happen a few times. When you put the motherboard back in, did you happen to tighten the screws too tight? Sometimes just that, will cause it to fritz and send it into boot loop which at that point, would have to be fully replaced because a part of the mobo is destroyed. Something just that small will cause it..
Ive seen this happen on almost every single model up to the XS max. It is possible
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I Had the same problem with an iPhone X after replacing the charging port, Solved this simply using an original salvaged charging port, 100% fixed. Some aftermarket charging flex cable aren’t working on iOS 13.x, They’re messing with something related to the thermal system, and forcing a kernel panic. (PS=The phone will keep restarting without any charging port,too).
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi, I have the same issue on an iPhone XS Max, it restarts it self only if I'm using it. The logs report the same error. It could be the charging port? Where I can find an original one?
댓글 달기
You might have damaged the charging port flex. You can also check the USB IC under the microscope.
A rare case of iPhone X Keeps Restarting - Motherboard Repair
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Check the charging port to see if there is any dust.
Or try restart it forcefully.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
@vicmohamed : I agree with your solution to this problem. I too just replaced the charging port to a water damaged iPhone XS with an after market replacement- I had no idea why the XS kept restarting after exactly 3 minutes. I spent a good amount of time researching the problem, and narrowed it down to the phone’s analytic reports showing the thermal system not being communicated with and causing the Kernel Panic. I saw these postings, re-opened the XS, and replaced the charging port with the old OEM (cleaned with 99%ISO) charging port cable. Problem immediately solved. I hope everyone has a similar experience and gets their phone working! Good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I did not connect power board, vibration flexy and keys flexy in the charging socket. nevertheless, the device is turning off with the same error, CPU usage is 100%.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Damage to the wireless charging pad on the back of the phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Icon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 11
전체 시간: 4,904
