주요 콘텐츠로 건너뛰기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 질문 전체 보기
White screen after repair
I replaced my screen on my iPad. Now it has a white screen only. Still haven't glued my screen down till I fix it but need help. What's wrong with my iPad. Why is it a white screen only but makes sounds and everything?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Was the digitizer glass changed or was the LCD display changed?
Note that the LCD Display from a Mini 1 is not compatible with the Mini 2 and vice versa.
If the display was replaced you can compare both displays old and new replacement side by side you’ll notice that the replacement screen either has a smaller or bigger rectangle metal covers at the bottom area of the screen.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Yes I'm the one who asked this question but forgot my log in info. I don't have the old one and didn't change the LCD screen. I ordered the screen for iPad mini 2 a1490.
Ah that makes sense now.
What happened most likely is that the iPad inner LCD display got damaged when it was pried up as the tape behind it is fairly strong and can get damaged from flexing the screen from under too much.
Most likely the LCD will need to be replaced. Try reseating the screen cables first and also clean the connectors with isopropyl alcohol brushing as it can be a loose connection.
댓글 달기
귀하의 답변을 추가하세요
Amy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 462
