주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
204 질문 전체 보기
Can you add a 2nd HDD to the $799 Mac Mini?
I've looked at the teardown and I must ask if anyone knows if you can add a 2nd HD to the $799 Mac Mini. The reason I ask is because you cannot get the AMD Radeon HD 6630M Graphics card and a second hard drive.
If I buy a $799 Mac Mini and choose to add a second HDD will there still be room or does the Radeon HD 6630M card get in the way?
I want the server version, but you have no choice on graphics cards. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I can confirm I was able to install a 2nd drive in mine just fine. In fact I replaced the stock 500G drive and installed two SAMSUNG Spinpoint M8 HN-M101MBB 1TB 5400 RPM 8MB Cache 2.5" SATA 3.0Gb/s Internal Notebook Hard Drive -Bare Drive from newegg.com.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
+ what cabling did you use?
I used the cable sold by iFixit.com, and the original Apple cable. I did peel off the black plastic from Apple's drive and transfer it to the new drive. Don't want any shorting.
댓글 달기
As far as I know there's no definitive answer yet. I guess we're waiting for someone to actually obtain the required cable and successfully fit a second drive in a 2011 mini with Radeon 6630M. It certainly looked like there was room in mine when I fitted my SSD the other day. It had the space under the HD just like in the teardown of the Intel-graphics-only mini. As soon as it's confirmed possible I'll be adding a second drive to mine for Windows.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shane Whitford 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 2,151
