주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Will an iPhone 6+ battery connect to an iPhone 7+ motherboard
I bought an iPhone 7 plus motherboard but I don't have a 7 plus battery I read that the 7 plus battery fits in the 6s plus does that mean the 6s plus battery fits in the 7 plus? I don't need it to go inside the phone and stay there I just need to connect to the motherboard to see if it works. Are the connectors different? Is it going to blow up? are there any batteries besides the 7 plus that have the same connector as the 7 plus?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
If you have around an iPhone 7 battery you can use that one to try out the board, despite different size, connector is the same. Unfortunately I don’t have any 6S plus battery to check, but I can confirm the 6S connector would not fit.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
It should work, the batteries from the 6 plus, 6s plus and 7 plus all fit vice-versa, it is good enough for testing.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mr_HaleYa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 20
30일 전: 100
전체 시간: 3,337
