Model Jura A1 the brew group motor rotates continuously.
The brew group motor rotates continuously in the same direction.
I change the encoder, but the problem persists.
What could be the problem?
좋은 질문 입니까?
좋은 질문 입니까?
Did you have the brew group apart?
I had this issue when I took the brew group apart and didn’t get the lower plunger in all the way when I assembled.
해당 답변은 도움이 되었습니까?
I’m working on a Jura A1 when starting it cycles a few times and shots off what’s the problem ?
해당 답변은 도움이 되었습니까?
I had the same problem. I dissaembled the brew group, I disconnected all the the connectors on the motherboard, then i disassembled the brew motor. I checked the encoder who is connected to the brew motor, it’s sensible so verify the encoder is well assembled to the motor with the metal “spring”/connector. assemble the motor (assembled with encoder) then the brew group and try again.
해당 답변은 도움이 되었습니까?
What is the "Encoder" ? where it's located ? on the motherboard ? I have some electronics skills
I have this issue, motor rotate non stop after I unmounted this part and cleaned it. Will try your tips, thanks !
해당 답변은 도움이 되었습니까?
It’s the brew group had the same problem took apart the brew group lowered the inside, plunger one notch, and it worked
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 447
