주요 콘텐츠로 건너뛰기
This is the 8-inch version of the smaller Fire 7. It includes 1.5 GB of RAM, a faster processor, and an HD display. The Fire HD 8 was released on June 7th, 2017.
22 질문 전체 보기
Can someone please help me locate correct USB charging port?
Can someone please tell me where I can get the correct USB port replacement for this device? I have ordered them off of eBay two separate times now and both times they have been incorrect. If anyone can help me locate the 100% correct charge port I would be very appreciative. It is for the 8th Gen model #L5S83A. Thanks, I have waited too long to fix this tablet already.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Do you have a picture of the charger port top and bottom? I can link you a compatible charger port once I see the pictures.
Is this soldered onto the main logic board or on a small daughter board?
댓글 달기
답변 1개
선택된 답변
Ben
Unfortunately that link Jayeff posted is to a USB port for the 7th Gen Fire HD 10 USB port. The correct one you need is this: Fire HD 8 L5S83A 8th gen USB port Also if you do a search for USB ports using that model you will find more of the same incorrect ports which you said you already purchased twice already. This is the only one I found that has the correct port pictured. Looks like they used a motherboard to show them matching side by side.
Hope this helps.
Best
Richard
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Yes, that is the correct model. Thanks so much I have ordered one and am glad someone could point me in right direction!
Ben
No problem. Glad I could help out. I notice a lot of sellers listing the wrong USB ports and I mean most or almost all of them.
Richard
댓글 달기
귀하의 답변을 추가하세요
BEN 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 722
