주요 콘텐츠로 건너뛰기
모델 A1200 with 2.16 또는 2.33 GHz Core 2 Duo 프로세서
113 질문 전체 보기
Is my power supply dead?
Initially noticed morning after a lightning storm - iMac worked fine prior to this.
First 3 diagnostic LED's are lit, but display back-light doesn't turn on. There's also no start up chime sound, but hdd seems to spool up, and white LED is on.
No visible signs of damage to power supply, but want to confirm output voltages. Are ps outputs +24v & +12v only?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
LED #4
Indicates that the computer and the LCD display panel are communicating. This LED will be • ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Contact your insurance agent. I've written many insurance reports on lightning hit machines. They usually end up getting replaced with a new machine because the hit can weaken so many things.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Thanks for the reply - didn't know what the 4th LED meant. Think it's worth trying an external display?
You can give that a shot but I don't think it's generating a video signal.
Going to test ps output voltage & also try external display, as they're inexpensive to do.
I'm also following up with the insurance agent, but how do they confirm the lightning damage?
댓글 달기
I have exact same problem on same machine. I also notice that HD is not spinning at all on startup. Did you manage to get this solved? I do suspect PSU in my case, but I was not able to find any pinout for PSU voltages for this machine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Larry Craig 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,513
