이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Low Temp for the Air Cond? Normally its located directly on the Evaporator, when the temp gets very low, it signals the control unit to stop the Compressor from pumping until the Evap temp raises a little to prevent the Evap from freezing over with ice. The Evap case is up under the dash and not fun to gain access to.
Duane Donaldson 의
