주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
Surface pro 4 screen replacement
Hello, i’m new here.
I would like to ask you if you could tell me which screen is mounted. I read that there are two versions and that the sp4 tablet is born with the Samsung screen. Subsequently, due to flickering problems it appears that the screens have been replaced by LG screens.
below I post a picture.
I would also like to ask you if the model in ifixit is compatible with my device and that I avoid the flickering effect
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Hi pisanivito,
I believe your broken display is an LG sourced display. I have attached an image of a Samsung display. The differences are subtle and they are interchangeable, provided you use the correct connectors. If you choose to use the IFIXIT display, it will be compatible with your Surface Pro 4, but you will need to order the correct display connector PN: X937072-001 . The N-Trig Digitizer should just be a hot-swap and although your connector for that looks different from mine, it should work with a Samsung display just fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi Logan, pianivito,
I am doing the same upgrade myself. M1010537-003 is the correct part number for the LVDS display cable to upgrade a Surface Pro 4 to a newer LG display. Cable X937072-001 is for the Samsung unit in your screenshot
Cheers, Neil!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
pisanivito 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 40
전체 시간: 859
