주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
6s stuck on apple logo, tried all the normal solutions.
Hello.
So I went to fix my friends iPhone 6s for what I assumed was just a simple battery problem. His phone randomly stopped working and got stuck on the apple logo, unable to go to the homescreen.
Tried a new battery, tried other batteries, same issue. I then took his screen/the new battery and tried on a different iPhone 6s and they both worked perfectly fine.
I tried a new screen on his phone, same issue. Tried unplugging all the cables (charging port, home button cable, front facing camera, back camera). Pretty much tried everything I know on how to fix this type of solution and unfortunately had no luck.
As a last resort I wanted to come here and see if anyone has any other suggestions for me to attempt. It stays on the apple logo forever before it has a quick flash, then back on the logo. Then eventually the screen just goes black. Appreciate any suggestions and help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 12개:
Try updating it through iTunes and see what happens.
Okay, will def give that a try.
Thanks
Could be that he doesn’t have enough space on the phone to start. Had the same issue and I had to completely restore the phone
watch this video will help you fix your stuck on logo iphone https://youtu.be/0XGMFmHLFCw
Watched the video, I know about 3utools. Doesn't the software cost money?
댓글 7개 더보기
댓글 달기
답변 1개
Software crash thats why is not loading, try to put it in DFU Mode , if you get it to DFU mode there’s the issue. you can try to update it but it might fail , if you flash it from 3Utools still gonna restore the device
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
It's in DFU mode, tried to flash it with 3utools while retaining users data and failed at 33%
Having trouble getting it out of DFU mode now.
댓글 달기
귀하의 답변을 추가하세요
Ian Romprey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 102
