주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
678 질문 전체 보기
iPhone 8 Plus home button stopped working randomly
I have an iPhone 8 Plus that I replaced the screen on last Thursday. Everything was working fine when I gave it back to the customer. Customer came back in today and said the home button stopped working over the weekend. The screens are Mobile Sentrix XO5 aftermarket. Tried Reinstalling that original screen with the home button, still nothing. I am in the process of doing a restore. Any suggestions or similar problems you have faced?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
This problem usually occurs from a small tear in the home button flex from the screen. But you have tried another screen so have ruled out the screen flex. This leads us to the home button assembly itself. You will probably need to put the home button assemble under a microscope and see if you can find the fault, it may be a small tear in the flex, damaged trace on the connector or the turtle IC Either way they are not easy to repair.
It seems strange that the problem did not occur straight away after the screen change. I would also make sure it is getting power to the connector.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
matt mocciola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 93
