주요 콘텐츠로 건너뛰기
모델 A1046 또는 A1095 / 1280x854 스크린 해상도
118 질문 전체 보기
PowerBook doesnt start even with ac connected
powerbook doesnt start up. after it wasnt switched off for a few days and battery was (322 cycles ) pretty much dead since it was not connected to ac.
i didnt use the book for quite some time ever since.
one day ago surprisingly i could start it while ac connected and i ran fine.
i turned it off and switched it on severals hours later. it started without any problem again.
today i tried again, it doesnt start at all.... neither battery (wich doesnt show any green LEDs) , and neither with ac conncted.
what your recommondation?
a
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Tell us about the AC charger connector light please.
hello mayer
theindicator lights on ac are green. no green lights on the battery though.
today i found out abaout a PMU restart.
great, and it starts this way. but when i turn it off it cant be startet normally, so i do the PMU again and it then
starts again.
orderd new battery...thanks!
댓글 달기
답변 1개
선택된 답변
If the battery drains completely, sometimes these machines will not start with the AC adapter plugged in. After the battery get some charge it will start up. Of course the battery has to be able to take some charge. If your's is almost gone, it would behave as your is doing. Here's where to get a new one: http://store.fastmac.com/product_info.ph...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I'D check the PRAM battery too...
댓글 달기
귀하의 답변을 추가하세요
Ren 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 743
