주요 콘텐츠로 건너뛰기
모든 연령의 아이들 장난감에 대한 포괄적인 수리 안내서 세트입니다.
961 질문 전체 보기
Schematic "Kissing Doll Coin Bank" Toy, Circa 1970, Japan.
The toy arrived disassembled, the cables were not identified, the PCB has no additional identification. Search Google as: "Kising Doll Bank Coin", the one I have, has a heart that lights up.
my english is a work in progress.
Actualización (01/11/19)
The mechanism has 4 switch, 3 physical and one of "coin", the problem is the set-up and synchronization between the melody, its duration and the movement of the figures.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Your English is fine. Without photos we really have no idea of how to help. Trying to find schematics on a fifty year old toy will be next to impossible.
댓글 달기
답변 1개
So the setup of the toy, I’m sure you can alter it for it to work. As far as the synchronization, it usually means that there could be a loose wire preventing the movement of the figures from moving to the melody as soon as it starts up and vise versa. If the duration of the song is not lasting for as long as it should and its cutting off, it could be the battery’s or then again a loose or sliced wire. They are very old and I wish you the best of luck trying to restore/repair it: https://youtu.be/H0jYEcTRTu0
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Juan rock 101 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 67
