주요 콘텐츠로 건너뛰기
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 질문 전체 보기
Trouble removing charge flex cable
Hi, i’m having a difficult time removing the charge flex cable that is soldered to the board. I’ve watched several videos but always end up ripping the pads off the flex cable when trying this on a couple broken ipod boards i have. I’ve tried using my cheap hot rework station set to 250c and also soldering iron and adding flux then using wick to remove the solder but still can never get the soldered pads to lift off the board without ripping.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Is a delicate job, in my case i use only the soldering pen and a lot of tin. But even more easy I just change this part, or you can transfer it from the new one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John Nguyen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 33
