주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
Won't power on. Is it the keyboard or logic board?
Acquired a 13” MacBook Air (Early 2015)
A1466 EMC 2925 that had suspected water damage. Opened it up, cleaned the board, however didn't see any real signs of liquid, no corrosion, etc.
No response at all when power button is pushed.
Using 45w MagSafe 2 Power Adapter (A1436).
When plugged in, light is green for 2.5 seconds then changes to orange. Green light when fully charged. SSD definitely feels warm to the touch and I think I feel some slight warmth to the battery when plugged in.
Since the power button is connected to the keyboard, is there a go around to try powering on another way to determine if the keyboard has a short?
It has sat for a little over a year unplugged and on my to do list. I tried powering on with the battery disconnected and plugged into the MagSafe charger as well as by battery alone, and with battery connected while also plugged in. (Did all 3 with and without the SSD installed.)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@conlledo Thanks Fernando.
I'm not seeing exactly the same points on my logic board. Can you point them out for me?
댓글 달기
답변 3개
선택된 해법
Here are the Power on Pads for that model, just make contact between this two pads (screwdriver or some metallic conductive tool). Also you said that SSD is warm, remove it a test, modern macs power on with blank screen until they load OS, and last thing try with a external monitor may has a screen back light problems.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thank you. No response though, so guessing it's the board. :(
댓글 달기
가장 유용한 답변
Sorry, It was for a macbook pro, Location of power pads
here are the pads.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
@conlledo - check out this vid The most common Macbook Air logic board failure - how to fix.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Brownbailey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 301
