주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 3월에 출시된 Apple의 13인치 MacBook Air 업데이트 모델은 5세대 Intel Core i5 및 i7 프로세서를 탑재하여 성능과 배터리 사용 시간이 약간 향상되었습니다.
Location of power pads
Macbook air with liquid damage, did a board cleaning and device powered back on. Now a couple month later it doesn't power up.
While trying to reset smc I notice there are no change to the charger indicator light. I suspect the power button has failed. I'm looking to jumpstart the macbook air to validate that, and if so, change the keyboard assembly.
I know Macboks usually have a couple power pads that can be bridged to power it up.
Does anyone know where they are?
thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
선택된 해법
Emmanuel Marti check the attached image for location.
이미지
이 답변이 도움이 되었나요?
점수 10
댓글 7개:
Hi!
I have the same problem. I have now located the "debug power button". But does not work to press on them. How do you do it? And why did you put a red circle around the black thing?
knutegil11 the red circle is from another guide where this image comes from. disregard it. you will need a flat head screwdriver or a paperclip to "bridge" the two contacts in the blue circle. If that does not work, then you are having plenty of other issues with your board.
Ok, then I guess my Mac is broken for sure... Thank you for answering :)
Before you get rid of it, track another ultrasonic cleaning with some Branson ec.
@gigabit87898 why? knutegil11 did not mention anything about water damage or any other damage.
댓글 2개 더보기
댓글 달기
답변을 추가하세요
Emmanuel Marti 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 78
전체 시간: 25,640
