MacBook Air 13-Inch Early 2015
I replaced keyboard, battery, fan…and trackpad ribbon cable and now only plugin keyboard and mouse are working.
Trackpad not recognizing finger touches. please advise
좋은 질문 입니까?
좋은 질문 입니까?
This series uses a daisy chain approach for the keyboard and touchpad. Basically, we have the keyboard at the end of the chain which plugs into the touchpad and then the signals for both travel up the touchpad cable to the logic board.
So replacing the touchpad cable won’t fix this! The touchpad its self is bad. Given the fact you replaced the keyboard hints of a liquid spill did you in. The touchpad also got damaged too!
MacBook Air 13" (Mid 2013-2017) Trackpad and here’s the guide MacBook Air 13" Early 2015 Trackpad Replacement
해당 답변은 도움이 되었습니까?
Well, in my opinion, you should check if everything is plugged in correctly. If that dosen’t work them I recommend going to the nearest apple store.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 136
댓글 2개
slowly re-seat the thin flat trackpad cable.
Veronique 의
Why did you replace all that stuff at once to begin with ? Liquid damage ?
arbaman 의
