주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
No service cant activate
My phone has no service does searching for signal tried other sims still an issue did a factory reset I wasnt signed into my icloud account when I reset it but now phone is bricked will not activate what do I do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Not much you can do, since all points to a hardware issue that needs a microsoldering repair where skills and tools are needed. If the iPhone was dropped in the past or the audio IC was previously repaired that would explain the why, although it would not change the picture.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Yeah I have all the tools and equipment but no skill
@consistent That takes lots of time, dedication and try and error, but it's also fun and might be rewarding in the end :)
댓글 달기
Im having the same problem, I even changed the busted antenna chip at the local store. Still bricked. Do you think theres a brute force way to activate it? A third party program maybe?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mark D Schlossman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 89
