The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
When you turn left or turn right do you notice if the sound is on the opposite side of the front corner of the car, example, if you turn right, do you hear the sound from the left side. Do you only hear the sound when you turn one direction only or both ways?
Sophia Montaldo what kind of noise is it? does it make that noise when you do not depress your clutch?
oldturkey03 의
Duane Donaldson 의
