주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
678 질문 전체 보기
wifi is grey out
i was going to replace the lightning connector flex cable in my iphone 8 plus.
I follow the steps in the guide and finished step 64, but i had to stop. The next step is to remove the lightning connector flex cable. I then follow the guide and put everything back. After i put back everything and boot up the phone, the wifi will not turn on, it does not let me toggle. I have double checked the bottom antenna and the top antenna, all seems to look fine. Please, can you suggest where i could have forgot a connector.
thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Unfortunately this is not an antenna issue. If your Wi-Fi is greyed out there is a problem with your Wi-Fi IC on your logic board.
This is not an easy repair and will have to be completed by a competent microsolderer that also has access to an IPhone 8 NAND programmer in case the Wi-Fi chip cannot be reballed and has to be replaced.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
cli168 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 524
