주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Ambient Light Sensor Filter Replacement
Along the top of a black iPhone 6/6S/7/8 (and their plus equivalents) there is a small white sticker under the ambient light sensor that filters light. This only exists on the black screens. I always transfer it over when doing a repair, but the odd time the area where the original is damaged has either caused it to go missing or has torn it causing it useless.
Am I able to get a replacement for this small white piece of (seemingly) paper? Without it, an active phone call placed to the ear does not black out the screen - resulting in buttons being pushed on the screen during a call.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I think you are getting confused with the ambient light sensor and the proximity sensor.
The proximity sensor is there to detect when the phone is up against your face, putting the screen to sleep.
The ambient light sensor is used to adjust the brightness of the screen in different lighting scenarios. This is the one that has the filter paper. I have never really noticed if this makes a difference if it is there or not on the black screens.
If you think the ambient light sensor is not working correctly due to the filter missing you could just cut a piece of filter paper to pop in there. I have heard of people using a white marker but I am not sure of the results.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Ok so if I have an iPhone 8 that the screen isn't locking while on a phone call (after the screen was replaced) would it be more likely that the proximity sensor isn't seated properly? I know the camera flex cable on the 8 is finickier to reset than the ones before it.
댓글 달기
귀하의 답변을 추가하세요
Bill Shannon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 597
