주요 콘텐츠로 건너뛰기
1.6 또는 1.8 GHz dual-core 프로세서, 2 GB 또는 4 GB SDRAM, 64 GB 또는 128 GB SSD
192 질문 전체 보기
Issue with battery or IO/DC power board?
I have a mid 2011 11” Macbook Air that appears to have an issue with the battery or the dc power board. I have a few questions and I’m hoping someone with more knowledge will be able to answer them.
The 2011 A1370 powers on without a battery but the fans immediately kick into high gear and continuously run as long as the machine is powered on even though the board remains cool/appears nothing is overheating. Is this normal behavior for this model?
Is it possible to reset the SMC without a battery installed?
Are there any thermal sensors located on the trackpad or somewhere else in the top case on this model?
If I also unplug the IPD/keyboard flex cable the machine turns on but the fan doesn’t even turn on.
I’ve had this machine for a while and when I had a replacement battery for it i recall it exhibiting various strange symptoms and I never got it to work properly so I returned it and left this thing sitting in a corner for the past few months. I’m now looking at it again and trying to figure out what exactly i overlooked the first time. I have checked out the logic board, took some readings, looked for shorts and everything appears to be good. Could the IPD cable or the IO board be causing an issue that would affect the battery?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
It’s not normal the fan stays at full speed, on the contrary, its standard speed is abt 1200rpm in idle or normal use VS the 6000rpm it reaches at full speed. If you have issues with the battery disconnected that answers your main question, it’s not a battery issue, the Air can run flawlessly without battery. With battery disconnected keep power button pressed for 15 seconds, that would reset SMC. If you can’t reset SMC with keyboard, you might have a bad keyboard, a bad trackpad, a bad IPD cable, a bad SMC, a faulty I/O board or connecting cable. Unless you have known good parts to try you’re in a bit of a rabbit hole here and you may get out only by purchasing random parts to maybe discover you have a board issue, not an easy path.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
butterfries 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 100
