주요 콘텐츠로 건너뛰기
{A1706 / EMC3214}—2018년 7월 출시, 이 MacBook Pro 13”는 쿼드-코어 i5 및 i7 프로세서 그리고 Intel Iris Plus 통합 그래픽 포함.
199 질문 전체 보기
Is my display dead?
I was using my Macbook connected to a Dell P2219 monitor using usb-c hub and hdmi cable without closing the internal display(at lowest brightness). But the display turned to blue/purple and mostly black after I unplugged all the cables. It stays the same after few hours and only works normally for external monitor. I already tried to uninstall some possible applications, update the system(but still 10.14.6) and reset the NVRAM, didn’t work.
Pic:
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The T-CON board over-heated killing it. This often happens when the back vents are blocked. The heat sink heat transfer fins are very close to the T-CON board as Apple moved it into the main case to thin down the display lid.
The problem is you can’t replace the T-CON board its self you need to replace the entire display! If you still have AppleCare+ coverage I would let Apple fix this as that would be the cheapest repair. If its not covered here’s the part you’ll need:
We don’t have a guide for the 2018 model but the process is the same as the MacBook Pro 13" Touch Bar 2017 스크린 교체.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Dan, do you have any additional info on the heat failure theory for the T-CON? I have a display that failed -- backlight is DOA, but the video signal is still good enough to drive the machine with a flashlight up against the screen. I look forward to any ideas or data you might have. Thank you.
If you can see a faint image on the display you just have a backlight power issue within the main logic board, not a display/TCON issue
댓글 달기
귀하의 답변을 추가하세요
Nayis Chan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 176
