주요 콘텐츠로 건너뛰기
건강 및 미용 관리 제품 수리 정보. 수리 과정은 보통 간단하며 일반 도구만 필요합니다.
385 질문 전체 보기
Silk epil 7 shaver head
The shaver head of the Silk epil 7 has a net on the top that gets damaged often. The company produces replaceable nets but I believe that if you have at least an extra net (from a previous shaver head that was replaced) it is possible to repair the part of the net that is broken. I would like to know if someone has tips on how it can be done.
I am attaching the photo
of this part.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
I can only offer a suggestion, the harder you push while shaving, the faster the net will get damaged, if you dont push hard enough, then you dont get a close shave. I recommend aggressive disassembly of the damaged unit to see what you need to do on another unit with a good net to see what would be required to repair one the correct way while waiting to see if somebody has done this before. Good luck.
댓글 달기
답변 1개
I don’t think there is any way to do that. The best thing you can do is replace that net with a new one.
Regards,
Lewis
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
CATERINA AMBROSINI 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 22
전체 시간: 1,162
