주요 콘텐츠로 건너뛰기
오랫동안 기다려온 인기 MacBook Air의 참신한 업데이트는 Intel Core i5 프로세서, Retina 화면 업데이트, 그리고 기타 수 많은 변경 및 업데이트를 포함합니다. 2018년 11월 7일에 출시되었습니다.
149 질문 전체 보기
Where is located the power on pads?
I have an liquid damaged MacBook air 2018 (A1932)
It was working perfectly except the battery and the power button/Touch ID, but I was really OK with it.
It was working since I wanted to downgrade from Catalina beta to Mojave, now it can boot only into internet recovery (that doesn’t work).
I tried every possible solution for this but nothing worked, now the only thing I could try is to restore the T2 firmware (BridgeOS) but to do this i need to boot the MacBook into DFU mode, but I can’t without the power button.
So I saw the power on pads on oldest MacBooks but can’t find it on the new one. Does anyone knows where?
The next question is, Can I use power on pads to boot the MacBook in DFU mode or reset the SMC?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Sadly, there are no power pads in this model. The control is all within the power button’s TouchID logic and its communication to the T2 chip. At this point you’ll need to go to Apple to get a new power button programed for your logic board. They are the only ones that have the ability to fix this.
Also be aware any data you have on your system will be lost!
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
If I buy a new power button on aliexpress, i know the touch id will not work but the power button doesn’t need to be programmed right? I can’t go to Apple.
Sadly, no the power button needs to be programed to your logic board. The only other way is to replace both!
댓글 달기
귀하의 답변을 추가하세요
Szilard Csoka 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 39
전체 시간: 2,145
