주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
NO SIM Card bad soldering job
Hey guys, friend of mine brought me this phone without working sim (no sim message in the left top corner). Immidiately after openin, I've recognized something bad about the sim card reader, it’s full of connected solder.. any idea how to repair this stuff? I’have microscope and soldering and hot air station.
Update (11/21/2019)
That’s what I’ve found underneath. Is there a possibility to repair those pads?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Arbaman may be correct about audio IC repair.
·         Clean the solder up so there are no bridges.
·          Check that (*#06#) brings up an IMEI number.
If it doesn’t, remove the logic board from the housing and check the audio IC, you will probably find it has been reflowed or repaired with jumper wires.
 If it has been worked on the most likely scenario is that they have put too much heat on the audio IC causing the solder balls under the baseband CPU to expand and bridge causing the “no sim and or searching no service.” This will require the baseband CPU to be removed and reballed, it is not an easy job.
If the repairer was not experienced they might have thought the sim tray was the problem.
If (*#06#) does bring up the IMEI number and there is no sign of audio IC repair go ahead and replace the sim reader.
해당 답변은 도움이 되었습니까?
점수 4
댓글 4개:
And repairing the pads under the sim reader?
I cannot make out any damaged pads. I can only see one image with a lot of solder. Clean the solder up so there is no bridging and check you get an IMEI number and check audio ic. The sim reader may be the least of your problems.
Even if all the pads are missing it is not that bigger job to run six jumpers. Just run them from J_DEBUG it is only a few millimetres away.
I've updated the image of the broken pads. The jumper should come from where to where please?
댓글 달기
If you are skilled enough and confidant enough then i would replace the sim reader, probably save you a lot of time than trying to make the bad one good
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
I would try to repair this one, but it's obviously a problem of the soldering mess inside isnt it?
@jrkstbl I agree with @danscreens , remove and replace, if there's already such a visible mess you can't rely on what's on the bottom. I wouldn't be surprised it's not the only damage on that board, especially if all started with an audio IC repair.
Any possibility to rpair the pads? It shows up that the pads under are already tear of the logic board. I can see very small dost of copper probably, is it possible to solder a new material to them? Multiumeter showing nothing when i put a probe on it, buts is so tiny, i dont know if i can believe the multimeter.
@jrkstbl Try to take and post a couple of pictures, so that we can see what you see. 기존 질문에 이미지 추가하기
댓글 달기
Put more flux and re-solder with pencil bit iron.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jrkstbl 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 375
