주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nomad는 Hover-1에서 제조한 7인치 직경의 휠을 가진 호버보드입니다. Nomad는 일반적인 호버보드 기능 외에도 블루투스 오디오 재생 및 LED 전조등 기능을 포함하고 있습니다.
Both indicator lights are red and wont stop beeping
Battery indicator and pad indicator lights are both steady red and it's steadily beeping, if I plug in the charger, lights turn to Orange and beeping stops, but when I unplug it, it goes back to red and beeping, only way I could get it to stop was remove the bottom and unplug battery
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Couple different things:
Usually the beeping and lights is a low battery, as you stated you have been charging the battery. Did you ever run the battery to completely dead? As that may have caused damage to the battery may leading to replacement.
The other option is that it needs to be re-calibrated by doing the following (from operating manual)
  • Make sure you have hover board on flat/even surface
* Mats should be even with eachother not tilted forward or backward.
  • Press and hold the on/off button for 15 seconds. Scoot will turn on.
  • Turn the board off and then turn the board back on.
  • Press power button twice and it should be calibrated
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Once I unplug it from the charger, it goes red and starts beeping, it will not turn on, so I would be unable to calibrate it, and I'm not sure about the battery, my son brought it to me like this and said it won't turn on or off, so I'm not sure the condition before this started
의
Sounds like a battery issue, if you are going to pop it open you can check for loose connections. Not sure if Hover-1 has replacement internals that are not after market. But I know my kid i could buy the internals pretty readily. Now they want a one wheel so that is my next project to figure out if it's even worth it....
의
댓글 달기
답변을 추가하세요
Jarrod Harvey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 57
전체 시간: 13,430
