주요 콘텐츠로 건너뛰기
2016년 3월 Samsung에서 출시되었습니다. 모델 SM-G930V.
425 질문 전체 보기
My phone only charges off laptop
My Galaxy S7 is almost brand new. I got it, and when I was doing some work I accidentally got a thorn bush seed in the charging port. Managed to dig it out but now it only charges off my laptop and wireless charger. It says there is a problem with the battery when connecting it to any fast charge cable, and it won’t do anything at all off normal USB. Data transfer also doesn’t work, the file simply gets corrupted when transferring it from the phone to a computer and vice versa. Any USB that fits tightly in the port won’t work, and any one that is loose is very finicky.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sounds like some pins might’ve been bent when the seed was removed from your charging port. If some data pins are touching each other, this can cause the issues you have described.
Unfortunately the charging port replacement process for this phone is nearly impossible without factoring in a screen replacement as well. I recommend using wireless charging for this device to prevent further damage to the charging port.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Well it can be done by an experienced microsoldering technician. We use hot air to remove the old port and solder a new one on. There are videos on YouTube that show it can be done.
@benjamen50 is this what you're referring to?
https://youtu.be/nzYmecOucgU
I've never seen it done for a Galaxy S7 but I suppose it's possible. Thanks for the info!
Yep that's how I do it. I do it for the S6 to s7 edge and note 5 too.
댓글 달기
귀하의 답변을 추가하세요
Shadow soul60 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 829
