주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
142 질문 전체 보기
no usb
USB not working at all. mac fires up but not a peep out of the USB
tried plugging different USB devices in which have lights on them but doesn't seem to be power available
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
If one of these answers fixes your problem, please go to that answer and hit the "accept" so that we can remove the question from the unanswered list. Thanks so much.
댓글 달기
답변 3개
선택된 답변
According to what system you are running different IOUSBFamily are needed. You can look it up here for a detailed decription of the problem and which files are needed:http://developer.apple.com/hardwaredrive...
or
just reinstall your system and the updates.
Debug releases of the IOUSBFamily kernel extension are used to provide information about USB device and interface detection, driver and interface matching, driver loading and information generated as a result of normal and abnormal conditions.
Unique debugging versions of the IOUSBFamily kernel extension are available for the different Mac OS X releases. It is important that you install the correct version of the IOUSBFamily kernel extension or you might find that the system will panic during startup or that your USB keyboard or mouse may not function properly.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Looking at the teardown guide the USB ports are soldered to the logic board. Therefor my first step would be to run disk repair. If that didn't help I would make sure I had a good backup--reformat the drive and reinstall the OS. If still no luck you may be looking at a bad logic board. I usually recommend getting an appointment with a Mac Genius for confirmation before buying a expensive part. Ralph
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If you go to /System/Library/Extensions/ do you see IOUSBFamily.kext ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
just looked in Extensions folder IOUSBFamily not there
댓글 달기
귀하의 답변을 추가하세요
mat 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 9
전체 시간: 1,960
