주요 콘텐츠로 건너뛰기
2006년 11월 북미에서 출시된 Wii는 인터넷 연결을 직접 지원하는 닌텐도 최초의 가정용 콘솔로, 온라인 게임과 Wii 숍 채널을 통해 게임 및 미디어 애플리케이션의 디지털 유통을 모두 지원했습니다.
288 질문 전체 보기
I have an error on my wii it's name is 003
hello
in one day i I worked to develop a Wii and then waited a bit, then after the completion of the development of a black screen appears written on it that there is something wrong happened to the 003 and now I can not find any solution
NOTE: The Wii was made in Korea - English language
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 8개
가장 유용한 답변
Error 003 is caused by system menu 4.2/4.3+ and ios70/80 on region changed Korean wiis
The FIX- You need to install ios60-v6174 into ios slot 70, 80, 90. Then Never ever update from Nintendo again. Be sure to install priiloader to block updates. Alternatively, you can use modmii to install the need patched ios.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
how to install ios60
My wii already has error code 003 . so it cant access into wiimenu. and it also did not install priloader
my question is
how can i use dop-mii. because my wii show only this error code. i cant go anywhere.
thank
댓글 달기
Nintendo's customer support page has a database for error numbers. It appears that 003 has its own page, though, asking you to call customer support directly. You might have quite the fun repair on your hands. After calling NIntendo, you might want to take a look at our selection of Nintendo Wii parts. Let us know what they tell you!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
how to install ios60-v6174 into slot 70, 80, 90
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This happens when you install a US/Europe/Japan Wii Menu on a Korean Wii, or add the Korean common key to a console with a U/E/J Wii Menu. Information on fixing can be found at https://wiibrew.org/wiki/Error_003
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Uh oh.
Sounds like you accidentally bought a hacked Wii. When you upgrade the firmware found the hack and now your Wii may be bricked. Try this: while holding down the reset button, turn on the power to the Wii. If a menu comes up then your wii is definitely hacked but it has a brick safety program to get you out of it. If nothing happens then you may be out of luck. Since you bought from Korea and it still allows you to play it in America then there is a good chance that your Wii is modded. I would say return it to the person you got it from but that seems to be out of the question.
Source(s):
http://www.wiihacks.com/general-homebrew...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yes how to install ios60-v6174 into slot 70, 80, 90
I want this also
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You can use DOP-Mii to install IOS60-v6174 into the correct slot. For System Menu 4.2, install into slot 70. For 4.3, install into slot 80. When DOP-Mii asks you if you want to change the slot for installation, click "Yes" and enter either 70 or 80.
WARNING: DO NOT INSTALL v6400!!! THAT IS A STUB AND WILL NOT HELP!!!
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I mean IOS60-v6400 in the warning. THAT one is a stub. Only install IOS60-v6174 into one of the slots I mentioned above.
pls help 003 error on my wii
댓글 달기
hm. my wii already has error code 003 . so it cant access into wiimenu. and it also didnot install priloader
my question is
thank
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
same error. Have you got any solution to this>
Same error. any solution to this please?
@saqib123 May I know if you have any solution on this?
https://wiibrew.org/wiki/Error_003 may be helpful, but it may be just cheaper to buy a new motherboard and start over (less than $50). Then mod using wii.guide and you're in business.
댓글 달기
귀하의 답변을 추가하세요
hamad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 31
전체 시간: 17,953
