주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
iPhone 7 vertical lines
Hi all
Have here an Iphone 7 which was dropped in the bath (kids!!) took it apart and cleaned motherboard amongst other parts with osyprinal and replaced the screen, all cam back to life and no issues for a few months, until now she dropped the phone which did not damage the screen in any way, however the screen is showing lines now, touch still works, I have changed the screen to see if that would sort it out but still with the same issue, see attached.
Any pointers would be appreciated.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Remove any power from the phone (including the battery) it could be that there is corrosion in connectors due to the water or it would be you damaged the pins when you plugged in the screen, corruption can be cleaned with alcohol and a toothbrush and if there is a bent pin you could try ending it back but most likely you need to replace the connector which required soldering and it’s a job for a professional
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
colin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 56
