주요 콘텐츠로 건너뛰기
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
Chromebooks not finding any networks/WiFi stuck on Off?
I work in education, and I’ve noticed this happen on multiple student devices. It’s a common issue on C213 devices as well. I’m not entirely sure it’s the network card, as we’ve swapped network cards out before and the issue returns weeks later. I’ve powerwashed and reloaded Chrome OS, but it doesn’t appear to be a software issue. I’ve also noticed that reseating the network card fixes the issue for at least a few days if not a few months, but the Chromebooks always come back with the same issue.
Has anyone dealt with this before? How do you go about repair?
Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 5개
not an answer but i have the same problem and would like to know if u found a way to fix it. I would be really helpful
No answer either unfortunately but following because I'm having the same issue as well.
@Marisa Esparza there may be no answer and not a lot of activity, since this is an old question. You may have better luck asking your own question and give as much information as possible. https://www.ifixit.com/Answers/Ask
This is how many take his jeep is there anyway that I can post to do my Chromebook next week
@cuia i had the same problem and i fixed it by hard reseting my chromebook. just press the restart button and the power on and i can turn on my wifi again.
댓글 달기
답변 3개
가장 유용한 답변
If multiple computers are unable to access Wi-Fi, I can think of three reasons: 1. A malware infection by a “worm” has spread to multiple computers and compromised their networking abilities, 2. The router or switch device that these computers are connected to frequently loses its ability to function properly and needs to be replaced, or 3. The network cards are fine, but the slots that they connect to aren’t.
I think that it’s most likely that the network card slots are faulty, and only provide network access after you re-seated the cards in there firmly. Sometimes NIC card slots can widen slightly, hereby affecting their ability to make contact with the cards. Frequently removing/replacing the NIC cards can exacerbate the problem.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Dan, thanks for your help! I’m positive there’s no infection on the Chromebooks having this issue. They’ve all been wiped and have had the Chrome OS reloaded, but the issue still persists. I’m also positive that the network equipment is working properly. I’d guess we have around 2,000+ devices on our network, and this issue is only happening on a handful of Chromebooks.
You did mention that it’s most likely the network card slots. I am also fairly certain it’s a hardware issue, but not certain if it’s the main board/slot,or if it’s the network card itself? I’m curious why you believe it’s the slot and not the card.
I think the problem may be the network card slots because you mentioned that you swapped out network cards before, only to have the loss of connectivity return later. If the problem persists even after you replaced the network cards, then either the slots are faulty or all the network cards you have tried are faulty. I think it's more likely the slots than all the different cards.
Also, the problem seems to be alleviated (at first) when you re-seat the cards or install new ones. There is something called "chip creep" that occurs when an integrated circuit works its way out of its socket over time. It is then alleviated by re-seating the loose chip. If the NIC socket doesn't have the means to keep the network card in place, "chip creep" can be a real possibility.
댓글 달기
Check the Networks Bandwith. If the chromebooks aren't able to connect to a 5g bandwith.... then the network settings need to be changed to a 2.4ghz network. Also check settings on chromebook. Make sure everything matches
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The same thing is happening to my Chromebook
댓글 달기
This happen to my so what I do was I noticed that my battery was low so charged it and let rest for somewhat two hours and I open it connected! I don’t know how this can happen but if you try this and this it might work probably.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Bailey Hecksel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 124
전체 시간: 9,928
