주요 콘텐츠로 건너뛰기
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157 질문 전체 보기
will not read games
I'm having a problem with my DSI XL. It will not read any games. I've cleaned the games, I've also did a system update. It still won't read any games. I don't know what do anymore. I'm afraid its broken but I just wanted to get another opinion. thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I am having the same problem!
댓글 달기
답변 1개
가장 유용한 답변
either:
1) the pins that make contact with the game are bent/broken/dirty. look into the reader with a flashlight and see if anything's going on. rubbing alcohol + small brush will take care of dirt. tweezers can take care of a bend. broken pins will require a new reader to be soldered in
2) bad solder joint between the reader and the main PCB. Reflowing is a pretty easy job if you have the tools, a replacement is a little more complicated.
good luck
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Camille 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 1,847
