주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
wifi greyed out, but works after some time after booting
A customer sent us a phone with audio IC problems. I noticed wifi is greyed out as well, so I checked info in the settings menu. It lagged and didn’t enter the info page, which is an indication there are problems with the wifi chip. Read this on a forum.
After a few minutes, wifi will work but will be bugged. The phone says the wifi is off while it’s on.
When I restart the iphone wifi is greyed out again. Does anyone have experience with this? The second phone in 2 weeks that have this problem. First time the customer came back and saying her wifi was broken again. I reset the network settings and it worked the first time so I didn’t read too much into it and didn’t charge her money.
Sounds like a wifi chip problem, but I wanna make sure. Repairing the audio IC isn’t an issue but I don’t wanna make things worse after heating up the board when repairing audio IC.
EDIT: Just repaired the audio IC and left it like that. The customer is aware wifi can fail any moment but didn’t want to pay for the repair. Can’t do anything else than that.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개:
Have this same problem, do you have a microphone issue by any chance?
The wifi chip would need to be replaced along with the NAND removed and reprogrammed with the new wifi Mac address and put back onto the phone. This along with a audio IC problem would make it economically not viable for repair.
Though intermittently working like this could be an unstable power line rail on the logic board that controls provides power to the wifi chip.
Took out the mainboard and saw the board has already been repaired under a microscope. I can see jumpers at the baseband PMU and god knows what has been done. It looks like a poorly refurbished phone. Not worth the risk so will just give back the phone.
댓글 달기
답변 1개
That is the common issues that on iPhone 7 & 7plus series.That is the issues of audio ic the pin under ic is broken that cause.So simply it`s a hardware job need microsoldring skills.That have other issues shows with that problem.If you don`t have idea on repair this may help you.
Speaker greyed out.
microphone not working.
videos recording stuck.
no sound on ear speaker.
all have common issues that related on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
My speaker symbol on calling is greyed out, when I go to voice memos it won’t start. Those aren’t the issues
The 2 problems you mentioned are audio IC symptoms
Yes, both are from audio ic.
댓글 달기
귀하의 답변을 추가하세요
KWH 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 7
전체 시간: 832
