주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
467 질문 전체 보기
Blown capacitor on logic board. What is it?
Long story short, my logic board went out. Started smelling like burnt electronics. Pulled the board out, and found one of the capacitors on the back side of the logic board was melted.
It seems like it would be fairly easy to replace, I just don’t know what capacitor it is, or where to find one. I know it looks like a D2E Case Tantalum capacitor, but beyond that, I’m not sure.
Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
The Cap is one of a group: C7370 which is a 68UF 20% 16V Poly-Tantalum in a D2E case
Here’s one source: Mouser
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Thanks a ton! I do have a follow-up question. (see second picture above) The blown capacitor is opposite the metal block (R36 446 RA7). I don't know exactly what that component is. Can't tell if they're connected or not.
Just wondering if there's anywhere I should check for a short or anything before replacing the capacitor?
Thanks again!
Also, the link seems to point to the wrong thing? It pulls up a 6.3V 220UF B case capacitor?
The R36 is an inductor coil Shielded Power Inductors
Thanks for the clarification!
댓글 달기
Found this question/answer that led me to the right replacement capacitor
Cannot find Tantalum - Polymer Capacitors that match
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brad P 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 27
전체 시간: 601
