주요 콘텐츠로 건너뛰기
Samsung Galaxy Ace II x는 1GHz 프로세서, 5MP 카메라 및 800x480 TFT 스크린이 특징입니다.
13 질문 전체 보기
How to repair water damage phone?
Hi,
A friend gave is old phone because it not working. After dissembling it I can clearly see that it had been water damage because of the water indicator. It a Galaxy Ace II X. I tried cleaning it with dome alcohol and bought a new battery. After pressing on the power button a can only hear sone crackling coming from the earphone speaker. I tried plugging into a a computer it not detected. Do what should I tried now ?
Huge thanks for the help.
Update (12/22/2019)
Thanks for the answer,
I tried to totally submerge the motherboard in alcohol but it still not working. I search for anything that look bad but it doesn’t seem like there any corrosion on the electronic. I took a picture of it. Huge thanks for the help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
This is a hard question to respond, because many things can have liquid damage inside, but this is my personal rule:
“Inspect for liquid damage and corrosion, wherever is bad or looks bad needs to cleaned be replaced, if liquid touched the motherboard/circuit board, the same rule wherever is bad or looks bad needs to be cleaned or replaced.”
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It looks very hard to fix it on your own. You may try sending it to a pro or a repair center if it is really important for you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jni Turbis 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 64
