주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Boot failure: phone quick-flashing on apple logo
Hello,
My sister’s iPhone seems to have developed a fault. It originally started with the phone randomly rebooting under battery power and then getting stuck on the apple logo. Once on the apple logo, it would continuously boot loop and not move past the apple logo. So it’d basically come on with the logo, wait a bit and then reboot.
If I plugged the phone into the mains, it would power up fine and then work. Taking out the charger would force it into a boot loop again (took some time for it to happen, time taken was random though - sometimes it’d do it instantly, other times not). Using PC to power the phone didn’t work. It had to be through the mains.
Now it seems the fault has developed one step further. Under battery power, it refuses to turn on. If I plug the phone into the mains, it will flash on the apple logo.
Here’s a clip of it in action: https://streamable.com/st8aa
Any idea what the problem is likely to be?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Yup. It was the battery. Replaced it and the phone now works.
댓글 달기
답변 1개
선택된 답변
The failure and behavior matches with that of a faulty battery, thus first step would be to check and probably replace it. You should get some indication of battery condition from battery settings inside the iPhone itself, or get more detailed info with 3Utools on a PC or Coconut battery on a Mac.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
hardstylez122 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 44
