주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
Ideas for removing a broken screw?
Hi there,
I recently purchased a refurbished A1502 and noticed that one of the screws of the heatsink was broken. The shaft is still inside the hole.
Is there a safe way of taking it out? The screw is decapitated a little bit deep.
Right now, the heatsink of the Mac is working with 3 screws only. Will this affect it motherboard in the future?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Use the screw extraction pliers to remove the shaft after removing the heat sink
Screw Extracting Pliers
MacBook Pro 13" Retina Display Early 2015 Heat Sink Replacement
Finding the screw at a decent price will be harder. Ebay would be your best bet.
MacBook Pro 13" Retina (Late 2012-Early 2013) Screw Set
MacBook Pro 13" Retina (Late 2012-Early 2013) Screw Set 이미지
상품
$59.99
Screw Extracting Pliers 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 7개:
The problem is that the shaft is like 2mm inside the hole. Any suggestions?
You'll likely need to drill it out using a left-hand drill bit held in a jewelers hand drill. If you're lucky the act of drilling will loosen the shaft and as you are using a left-hand drill will help walk it out.
What I've read, people don't recommend using power tools on motherboards and pretty concerned about a rMBP motherboard.
Will this work? Otherwise, a grommet change is the ultimate choice.
https://www.amazon.com/Moody-Tools-58-06...
They do not have good reviews. Thanks anyway.
@danj
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
Joel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 371
