주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2.3L 4cyl or 3.0L V6, 6th Generation
Car dies while driving
I have a 1999 honda accord lx and recently the car has just been cutting off while driving. I can get it to start again but only once it cools down. Is this a possible starter relay issue.? Thank you for any advice you can give.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Probably not the starter relay since that wouldn’t kill the engine. First step would be to see if there’s anything specific that’s happening when the engine dies. For example, is it only after reaching a certain temperature? Or only when turning/going straight/hitting a bump? If it only starts again after cooling down, that indicates it’s a cooling system issue. There might be an overheating problem or there might be an ECU issue that’s misinterpreting temp sensor or other engine parameters. Unless the engine dies at a very specific time, every time, it could be difficult to diagnose without ECU/BCU/engine code reading tools.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Devon Blom 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 469
